AquaRite not working
timd
0
Jul 20, 2012
25
Cleburne, TX
Moved from HERE
I have the same similar issue with my T-15 cell. My Aqua Rite also does not display the cell type in the display, but I am on version 1.10 and it is configured with a jumper on the board. I purchased a new cell (Hayward T-15) yesterday, but my Low Salt and Inspect Cell are still solid red. After further investigation, I believe my issue may be with the thermistor on the board. I have ordered a replacement thermistor that should be here today, will attempt to solder it on tonight and hopefully will solve my issue. Aqua Rite.jpg
Your thermistor definitely looks ratty in the pic.
This is the basic information we need to know in diagnosing a problem:
  • Report all readings when you..
    • Move the switch from auto to off and check all of the readings.
    • Move the switch back to auto and recheck the readings.
    • Move the switch to off for a minute and then back to auto and recheck the readings.
  • What are the first seven characters of the cell and box serial numbers?
  • What is the actual salinity and how are you measuring it?
