Hi - new to TFP, but WOW - what a great find!
I suspected my Aquarite was not generating chlorine, and discovered power and generating lights were cycling on and off every 30 seconds or so. Based on threads I found here, I ordered a new resistor from DigiKey. Old one was cracked and fell apart when we removed it.
New resistor was soldered on the panel, I reinstalled the panel in the box, but now the pool circuit breaker will not stay on. I can move it to the on position and then it slowly moves itself back into "OFF" position.
Only thing I noticed in the box is a possible burn mark that I'm 90% certain was not there before I reinstalled the panel. Unfortunately I was at breaker box when I tried turning power back on so I didn't see what happened. Photo is attached.
Any advice?? Thank you in advance!
