Hi there,
Like many of the similar threads I am a new owner to this pool. I assume this equipment is several years old and the previous owner claims to have had no issues
. When I fired up the SWG I was getting several error codes (FWIW they were 172, 173, 186, 187, 188). I followed the troubleshooting guide and 1) cleaned the sensor and 2) rewired the unit to match the existing 120V input per the manual (from the factory 240V internal wiring). With this change everything lit up and was error free for about 10 mins. Is it possible that this unit worked previously if it was incorrectly wired?
I am now getting error codes 120 in the forward direction and 121 in the reverse direction. To troubleshoot these I have 1) increased the salt content to 2900 (I know this is a bit low but the add salt light is not on), 2) cleaned the cell with acid, and 3) inspected the DC cord. The error codes persist.
I have now run through the various test points as follows:
Back board
1-8: 77.7 VAC (should be 75 - OK)
2-7: 69 VAC (should be 65 - OK)
3-5: 20.9 VAC (should 21 - OK)
Cell test points: 36.7 VDC (should be 22 to 28 - ISSUE)
Voltage at cell: 36.7 VDC (should be 22 to 28 - ISSUE)
Front board
A-C: 20.8 (should be 21 VAC - OK)
K-H: 0.04 (should be 120 mVDC - ISSUE)
Using the test buttons:
Salinity+R-Temp+Salinity: 2.7 (should be 2.8 gpl - OK)
Salinity+R-Temp+Temperature: 74 (should be 75 degF - OK)
H-Temp+Salinity+Chlorine-Down: 91 (should be 91 degF)
So, based on this info, am I identifying the right issues and therefore do I need to replace "the cell and DC cord" only? Or are there issues with the boards as well?
Appreciate the help!
Back board
Front board
