- Feb 17, 2021
- 3
- Plaster
- CircuPool RJ-60
Has anyone repurposed the solar temp input to read a temperature input from another location? I would like to add a water temp sensor to the outlet of my heat pump so I know the water temperature delta. Is this possible or would it screw up the contorl function of the heater control? I am hoping this can be used as a spare analog input so I can read my heater temp output temp.
Thank You
Thank You
