Hi,
Been looking at this site for a long time for all the excellent advise - best resource on the net - so I thought I would join to ask two questions. This is the first.
In Australia it is quite common for pools to be built with a separate solar feed and return for solar panels (lots of sun here in Australia). Not wanting to go into the benefits or not (there are a few posts on this on this site and around the web).
But I have one specific question. Is it possible to run a separate solar pump in the Aqualink RS system (assume the latest Rev T) without the filter pump (and SWCG) operating. The reason is because here in Oz the they are built as two separate lines, I may want to run the solar longer than the filter pump operates for the day?
If not - can any experienced Aqualink RS owners offer up possible hacks or workarounds.
Many Thanks for any help you may provide
TN
I note that the Aqualink RS installation manual page 10 states as per below....
To use Solar Heat
Highlight SOLAR HEAT and press SELECT. Use the SELECT button to turn SOLAR HEAT on or off.
HEAT PUMP: If a Heat Pump is properly connected to this system, HEAT PUMP will appear on the screen in place of
SOLAR HEAT.
If a solar sensor is not installed, EXTRA AUX replaces SOLAR HEAT and may be used to control an auxiliary (see
"Auxiliary Equipment" to turn on or off EXTRA AUX).
For solar heating to take place, the SOLAR HEAT (in EQUIPMENT ON/OFF) must be enabled, also the filter pump
must be on. Solar temperature must be at least 5° F above the water temperature and the water must be cooler than the
thermostat setting.
TN
To use Solar Heat
SOLAR HEAT.
thermostat setting.
