Hi there- First time on posting as I am completely stumped. I have an aqua rite electronic chlorine generator with a t-15 cell.
It is currently running, but the power light does not illuminate, but the other lights do. The check salt light is currently on.
When I first opened the pool this year, I added salt and let it go. I came back the next day and noticed my readings still weren't correct. Then I noticed the power light wasn't on. I troubleshooted it and found out about replacing the thermistor (black disk). I did that and I still have the same problem, so it seemed to be the board. I have replaced the board, but still have the same issue. HELP!
Display readings:
Average Salt Level- 2600
Temperature- 80
Cell Voltage- 26.3
Cell Amperage- 5.30
Desired Output- 100P
Instant Salt Level- -2500
Program Code- AL-0
Main Board Revision- r 1.59
Cell Size- t-15
From everything I have read, those are all normal readings, besides salt which leads me to believe it isn't generating even though the light it on. Is this a cell issue? I cleaned it when opened as well.
Display readings:
Temperature- 80
Cell Voltage- 26.3
Cell Amperage- 5.30
Program Code- AL-0
Cell Size- t-15
