Hi all,
I'm new here and just moved into a house that has a pool w/salt chlorination installed. It is a AQL-P-4, Software revision 2.41, display software revision 3.11. The pool inspection stated that the salt cell was bad / needs replacing since it was 10+years old. I bought a new generic replacement T-Cell 15 which matches the old one. I have it all hooked up and went through the settings (config menu) and noticed there is no option to select the size of the t-cell. I added salt 3 weeks ago per the salt calculator and now the display says "Chlorinator Off High Salt/Amps". I have an 18000 gallon pool, and there was no salt in it when starting this. The calculators (used multiple sites) all said to add 480lbs of salt to raise the levels to 3200 so I added 12 40lb bags. I have checked the back of the board and the solders look fine, no burnout/bad spots at all. It actually looks like new on back of it. When running the diagnostics it reads -24.0V > 10.00A > 89F(temp) > 6200PPM. Do I need to dilute the pool, or is something wrong with the board that I don't have the setting to check the size of the T-Cell? It goes right from the salt/minerals setting to the pool/spa config options. Any help would be great.
