approximate dimensions of this railing
sherby
1
Shinglehouse, Pa
Could someone please give me the approximate dimension of this railing. I would love to build one. If it is possible could you please give me the dimensions by PM (Start Conversation).
It looks like regular 1.5" PVC.
That is not secured in any way, so I don't know how it will work.
Also, it is not strong enough to be reliable and it might break during use, which could cause injury.
Schedule 80 PVC pipe and fittings would be stronger, but still probably not strong enough.
You can get the same parts in schedule 80 and copy the model if you want and you accept the risk.
You would need to secure it in some way.
You can have a rail made to your specifications.
You would need to core drill in anchors and the anchors would need to be bonded per NEC code unless you get a Saftron rail, which does not require a bonding connection.
