I'm baaaack!!! LOL, something about a few warm days and wishing the water was warmer gets me in the mood to get the pool ready
I left the pool running through our short winter, but otherwise stopped testing anything. With the weather warming I started looking and found today my entirely rebuilt Polaris last year already has an issue. I took it apart only partially and something is binding on the flywheel side. Too lazy to mess with that so I dropped it at the pool store today for them to repair instead. It was picking up fallen leaves until only a few days ago though. The pool also stayed crystal clear the entire winter, until the bad storms this past week finally diluted the salt enough to stop the SWG
I have just a hint of cloudiness now after making it all winter due to not paying attention! That was also corrected this morning and a nice steady stream of bubbles now and on super-chlorinate and hopefully not too late.
Right now I'm only getting chlorine levels up and will start testing and adjusting anything otherwise in a week or two. While at the store though I figured I'd get a free never accurate test of everything and looks pretty good for a Winter off
FC - 1 (should be rising again now)
PH - 7.5
TA - 50
CH - 70
CYA - 40
Since my TA was at 60 when last checked, and my top-off water is 50 with free storm top-off at zero the TA is likely pretty accurate. CYA if reading through this and my past posts started probably near 300 but had already been dropping well just due to backwashes or draining off after storms so "may" be close to accurate. Other than the hint of cloudiness having me worried I'm pretty pleased with how it survided, seeing friends pools that are green and waiting for a Spring Green to Clean dump of chemicals!! They also tried to sell me Phosfree due a 200ppm phosphate of course, lmao, as well as things to bring up TA and CH but I didn't point out that I am quite happy with a TA of 50, thank you very much
Back to work on it soon though, other than some physical cleanup and getting FC back up. I'm also considering adding a heat pump, just to get it swim ready sooner and extend it further into the fall. I replaced EVERYTHING last year, so I must have something to add or mess with, right?
