Hi everyone,
We purchased a 12'x22'x48" Bestway pool from Costco. I've had some work done on trying to level the spot. It is going along the side of our house since that is the most level area that doesn't get a small stream flowing through it during a hard rain. Red outline was the original pool placement.
My first plan was to cut down both the distant tree in the pic and the close tree with the overhanging leaves. But decided to just cut the far tree down for now and do some trimming of the close one to hopefully eliminate or limit overhanging branches limbs. Does anyone actually have branches hanging above their pool? If yes, how hard is it to manage falling debris? I suspect I'll need to cut down the second tree too have a chance at a decent pool temp, even if the pool stays clean enough.
I'd like to do xps foam insulation under the pool. Does anyone have an opinion on 1/2" vs 1" thick? Also thinking I may need to get some mason sand, or something to allow the ground to get a little smoother/level under the xps. Next up is to dig sink some 8x16x4 inch pavers into the ground to match the height of the foam, and get them level with a water level.
Any comments on the plan are appreciated!
