Any ideas what could cause this
Justinlee124
2
Medina, Ohio
Hi there,
I have had an above ground pool for what will be the third year, I live in Ohio so the pool is only used 4-6 months. I have a Raypak heater 156 A. I was opening the pool and the heater fired right up and was working. I turn the pump off and there was a gurgling sound and it split the water hose going into the heater from the pump spraying boiling water into the air, I thought maybe it was a fluke and bought a new hose and it did the same thing. Turn the pump off, gurgling noise from heater and so much water pressure it split the line. I have attached picture. Heat exchanger had some minor build up on it but have cleaned. Not sure what else the issue could be???
