Another DIY Build
Here's what I have for prep work:
Welcome to Part 9, wherein we talk about installing the liner  (actually, dropping the liner will be part 10 – we’ve got to be sure your pool is ready to accept the liner first)
Your floor is all set, so you think. Double and triple check the floor! If you used vermiculite, sweep the floor at least 3X and pay attention to where you are sweeping, you WILL notice imperfections that should be addressed and, on your first sweep, you’ll pull the pins that held the strings and have to patch them.
As opposed to the normal vermiculite mix you used to trowel the bottom, the patching mix should be heavier on cement and WET, this will help you ‘feather in’ the patches. I use a 5 gal. bucket to mix it in, I ‘parfait’ the mix (3” of verm., 1/4” cement, another 2 -3” verm. And ~ ½” cement and mix it dry before adding water) using a ‘margin trowel’ [it has a square edge] helps to insure that there are no pockets of unmixed material in the bottom)
The sweeping process is a great chance to ‘level out’ your toweling. You can site down the various slopes and plains to see if you are OVERLY high or low. Low spots can be filled in with the patch mix and high spots can be scraped down with your trowel ;) Please remember to sweep 2X after the patch material has ‘set up’! You DO NOT want any debris on the floor when you drop the liner!!!!!
When I say ‘sweep’ I’m talking about using a SOFT bristle ~2’ wide deck broom – you don’t want to sweep with a hard bristle broom (you’ll just end up digging into the fresh verm). Try to keep the bristles dry! Wet can keep you from getting all the dust/ small bits up!
After the first sweep, clean the walls/ any surface that will be under the liner! Use a trowel to remove any vermiculite/ concrete ‘splats’ and wipe the walls with a cloth to remove dirt and dust.
OK, you think the floor is all you have to take care of? Guess again! You need to install the coping (or liner receiver, if you’re going with a cantilever deck). Before you do that, however, you should duct tape all the seams on the walls/ stairs – you want the vessel to be ~ airtight before you introduce the liner to the pool. Now install the coping – this should be as easy as putting it on the wall so the lip is flush with the panels and screwing it down (sometimes the corners are a little off – I’ll help you with that if you have a problem, but it’s for another post) Sight down the walls and corners once it’s in place and make sure everything looks straight. Once you’ve got the coping all on, duct tape the inside edge (remember that we want the pool to be ~ airtight)
Now put on all the under the liner gaskets, you can use duct tape or spray glue for this, make sure the screw holes line up and try not to cover the holes with the duct tape. If you choose to use wall foam put it on and cut it out from around the gaskets (I’ll have to make an ‘addendum’ for wall foaming a pool- if anyone wants/ needs it).
With one more sweeping of the floor, you’re ready to drop your liner 
Sorry for the delay... it's keep the gasket(s) from shifting while the liner is pulled over it. A thin layer of silicon could be used, but it's more bulky (we want to keep the liner as close to the under surface as possible). The pressure on the faceplates from the screws will create the seal, but a 'glob' of silicone could prevent it from fully sealing.
Water in and filling up. Main drains lights and skimmers all have gasket liner gasket face plate. But my returns only came with one gasket is this normal or did I get shorted. If its normal is it correct to assume gasket liner faceplate.
It's normal for there to be the 1 'rubber' gasket only behind the liner (which comes secured to the inlet fitting).
The older ones had 2 of the gaskets but, when they started putting a ridge on the back of the faceplate, they found that it would seal just as well.
Yours are fine :cool:
Long overdue picture. Lots more to due but glad concrete is all done. Picture is a panoramic from my phone to its not the greatest quality. I did give in and paid a crew to help me out. I still need to etch concrete for border and tile pieces, stain concrete and put stone on wall to match the house.
Looks beautiful, Buck! :goodjob:
You did a superb job! :cheers:
I'm sorry I haven't been able to give my advice on liner dropping but other things just keep popping up. (looks like you did fine without it :party: - have you got any tips for the other DIYers on dropping liners?)
Did you get a SWCG with your automation?
Do you plan on closing and covering the pool in the winter?
One other thing, please have folks be gentle on the ladder until the deck has cured for 3 weeks :!:
Yes I did SW just hope it can keep up with the size of pool if not will add another system. Don't plan on covering it or closing it didn't get cold enough. Trying to keep kids off ladder. Waiting to install diving board and my kids can't stand it. Thanks for the kind words and help.
