- Jun 24, 2021
- 16,366
- Vinyl
- CircuPool RJ-60 Plus
Thank you. What speed were you running when you were running before now? Do you know if it is wired 110 or 220?VSFHP270DV2A
It was running at 2000 rpm. I believe at 110.Thank you. What speed were you running when you were running before now? Do you know if it is wired 110 or 220?
Ok, so then, given the 1950 for 24/7 vs. 2000 for your reduced run-time, from a $ perspective makes sense to run a reduced schedule.It was running at 2000 rpm. I believe at 110.
MA needs 15 mins with good circulation.Does adding the MA take as long to register as the CYA?
Bingo. Regular testing is KEY. You'll spot any red flags long before they are emergencies. Your pool will tell you everything it needs, if you listen. It will not listen to you no matter how hard you try.As the temps warm and the kids use the pool more frequently, I will adjust
No. With pump on you should see change in 30 minutes. WEAR SAFETY GLASSES. Pour down wind. Pour acid into water. Pencil stream slowly over the return. Swirl with a pool brush.Does adding the MA take as long to register as the CYA?
For once, that's not a bad idea. Most of the ones at HD/Lowes are half strength and you need to buy twice as much.Or just go to pool store and ask for one?
You are asking "PoolStored" if you should go to the pool store? *Really*Or just go to pool store and ask for one?
^^^Thispaint aisle in the hardware store.
Noted...will stay away from Pool Store. Love going to HD anyway. Thanks!!You are asking "PoolStored" if you should go to the pool store? *Really*
^^^This
Home depot jacksonville.
HDX 1 Gal. Muriatic Acid (2-Pack) pH Adjuster 10031HDX - The Home Depot
HDX 1 Gal. Muriatic Acid (2-Pack) is a powerful pH reducer for your swimming pool. It comes ready to use, with no pre-mixing required. This fast-working chemical helps prevent scaling caused by calcium-basedwww.homedepot.com
I am already the master.You will be so proud of yourself when you are the Queen of your pool and master of your domain.
The store closest to me has 90 in stock. I think that should cover it .@Hollybody You need to go to this HD. They have 66 in stock.
Atlantic And Girvin #6365
6.6 mi
12721 Atlantic Blvd
Jacksonville, FL 32225
