Aluminum Fence - how to get a wider opening?
RichTJ99
0
273
Katonah NY
Hi,
I have an aluminum fence around my pool. I also have an ATV which I use to bring supplies to & from the pool.
http://i.imgur.com/d0xbfeL.jpg
I would like to figure a way to get a larger opening. Is there an easy way to either put a hinge of some sort on a part of the fence or some way for easy (ish) access to drive a quad into the pool area?
The regular gate I have now is about 45 inches & the quad is about 47 inches wide so it wont fit. If I could easily remove a part of the fence it would be a snap to drive in & out.
Any advice or suggestions?
Rich
I am sure you can cut it off and make it into a gate. Whether it is easy or not is up to your abilities.
Just make sure it still complies with any codes ... like self-closing and latching with high latches.
