Alot of dirt in pool
Apr 17, 2020
8
Houston
I had new grass installed in my backyard and now tons of dirt has settled on the bottom of my pool. I have a robot but it's too much for it to pick up. I wanted to Invest into a riptide or hammer head but I dont know if they will get the fine dirt up. I current have a hole in my de grids and have new ones on the way. How can I remove this dirt from the bottom. Oh by the way I also have a small external pump that I can plug in but its hard to prime.
I have a dolphin robot cleaner but is so much dirt on the bottom the robot stops moving after 5 minutes because the canister is full so I'm looking for some alternative sources on cleaning like using an external pump or going with a hammer head cleaner with a mesh bag
Please fill out a signature line with details about your pool and equipment, and how you sanitize and test the pool. You can find the signature block area under your screenname at the top right. This will really help us answer your questions better.
Thanks.
