Almost there with SLAM!
I can’t see your
PoolMath logs to judge but sounds like you’re making progress in the right direction. Don’t forget to do all the things!
Fwiw- My husband thought I was nuts the first time I slammed our pool lol 😂
But he has learned to trust the process !
My husband commented last night about how I was burning through chlorine so I can get him off my back soon 🤣
On the contrary. If he ever questions why you need *a* jug when then pool is so clear, you can ask him if he prefers how many jugs you needed when it wasn't clear. (y)
I can’t see your
I haven’t been logging, I’ve just been plugging my fas-dpd results in to figure how many gallons to add then redoing each test. I know I’m close but not there, still have dead algae on the bottom. My little bot just isn’t up to this I’m afraid. My water is pretty darn clear though so soon…soon.
Reactions: Mdragger88
Sometimes you just need to manually vac.
I do siphon vacuuming so it wastes the water when there’s stuff I don’t want going through my filter but its not as fast/as much waste as it would if I had it hooked to the pump.
Reactions: Phack1 and Newdude
