I am closing my pool today. After lowering the water a few inches below the skimmers, I added a quart of HTH Super Algae Guard 60 (polyquat 60) and let it circulate a few hours. The water is now cloudy enough that I can't see the remaining leaves on the bottom (I'm fairly sure there are a few left down there), and there is foam on the surface. Did I add too much? Should I do anything about it, or just go ahead and close it? I would like to finish closing the pool today.
Also, I read somewhere (here?) that with a mesh cover, it's a good idea to put floaters with chlorine sticks under the cover at closing. Should I do that, or will that raise the chlorine level enough to destroy the algaecide?
