- Jun 26, 2015
- 478
- Vinyl
- CircuPool RJ-30 Plus
SLAMming my pool right now. Getting ready to install a new SWG and want to have water perfectly balanced before install. The water is very clear now, there was a lot of debris prior. There are some light brown sandy spots that don't budge when brushed. Do have hard water, was wondering if it could be buildup of some kind? If that is the case, what's the lowest PH the vinyl could take to release? I had scaling on our hot tub once and was able to lower to 7 and scrub it off after a couple of days, but not sure this is the same. This morning my PH was over 8 ( not unusual, it's something I constantly have to control throughout the season ) I lowered to 7.5 then dosed per calculator to 7.2. Since then I have chlorine too high to test. I'm going to do overnight test to set if I pass, but not sure what to do about the marks. Today I did vacuum up chunks of white calcium looking stuff from the bottom of the pool. About the size of a pinky fingernail, able to break apart.
