Hi,
I "reopened" my pool probably around 6 weeks ago and it was completely green (even had some living things swimming in it!). I started the SLAM process and have kept very high chlorine levels without any CYA added (CYA below 20). The only step I didn't initially take was to adjust pH levels.
Today it's night and day, the water is very clear.
However, while the water is very clear for the past week or two I am seeing a persistant small amount of algae on the floor. I've added photos to show this. It comes back after being vacuumed or brushed. I have been running the vacuum every other day.
It's been hot the last few days so I finally added instant conditioner to bring CYA up (yes, I know I probably wasted money on having to add extra chlorine without the CYA before this).
I also thought the reason for the SLAM taking so long is that I didn't initially adjust pH levels. I let FC fall below 10 and yesterday I re-tested the pH levels and added acid to lower the pH.
Today's tests are:
FC: 13
CC: 0
TA: 180
CYA: 40
pH levels (tested while FC was under 10 after adding acid): 7.4
Results above are prior to adding extra chlorine to bump up to SLAM levels.
My question is: based on the photos can you tell what type of algae this is? Is it algae or just dirt? I've also heard that dead algae could settle on the floor, could that be happening?
I'm surprised my CC is zero as if there was algae, I would have expected CC to be higher?
Do I just keep going with the SLAM process for another few weeks? It feels like I'm doing something wrong since it's at least a week or maybe two where the water is clear but I still have the "dust" on the pool floor. Most other SLAM posts appear to resolve in a few days and at most a week or so.
Photos (they were too large to upload, there are 3 photos):
Thanks!
Today's tests are:
FC: 13
CC: 0
TA: 180
CYA: 40
Thanks!
