I constantly (except once) have air in the pump. Not a lot, no visible bubbles coming from the return but it may be causing my foam. I can also hear some air in the filter. Everything seems to be functioning so I haven't worried about it.
When I added the vacuum plate and hose, filter pressure dropped from 13 to 10, and the pump basket emptied about half way. I could see the full stream of water entering the pump (stream was not submerged). Still no visible bubbles from the return. I vacuumed briefly and things seemed stable, but I was wary and didn't continue more than a couple of minutes.
When I shut the pump off, it instantly mostly refilled with water. There was maybe a bit more air than before vacuuming, but less than when I remove and replace the lid to clean the basket.
Thoughts?
Thoughts?
