I have seen other threads on this issue but have a few questions. For the past year my pool pump fails to prime after being off overnight. I can self prime it and it works but there are air bubbles coming out the jets, air in my pump basket and I hear air in my sand dollar filter as well as coming from my fountain feature. it all points to a leak on the intake side. So I had the line from the filter basket to my two skimmer baskets pressure tested by a leak detection company. The said both lines were holding pressure. (They tested for 10 minutes at an ungodly PSI) I only use one of the skimmer baskets Because the other does not fill the basket enough when the diverter valve is set to that side. I assumed it had a clog several years ago, long before my current bubble problem And if they tested it from the filter basket and the diverter was leaking to the defunct side it would have not held pressure. Next I replaced the filter basket lid, clamp and o-ring. Lubed the o-ring. All is tight. I am waiting for a strap wrench to arrive so I can take the the coupling off the front of the basket. The pressure test would not have been able to test that joint because the air bladder used was inserted in the line past it) my pool store advised me to use silicone on the entire joint including the threads rather than plumbers tape. Is this advisable? As well is it perceivable the the joint on the out port of the pump leaks as well and I should do that one too? I truly can not find visible any leaks on the non suction side (no water). It would seem obvious that you would see water leaking on that side. BTW the sand dollar is new, and the filter valve is new. Any ideas thanks
FYI update 2024
If anyone has this problem……..It turns out my multiport valve was the culprit. It was leaking air back into the system via the backwash hose. Replaced it completely and all the priming problems went away.
FYI update 2024
