Hi
Just opened the pool for the season (first opening since it was built last summer).
The water is filled is halfway above the skimmer box.
I pulled all of the plugs in the 2 skimmer boxes.
I primed the pump with water from the hose.
Filter is put back together. The plug is back on the filter at the bottom.
There is a hole in the skimmer/main drain line back to the pump that the company drilled to connect a compressor - that is plugged (I added tape to make sure I had a good seal.
The pump O-ring is intact and I added some grease to create a good seal.
Not sure why I still have air!
See pics and thanks for the help!
