Air getting in
Jcsmith9
172
Birmingham/Alabama
When I turn the pump off for the night and come back out the next day to turn on air is blowing out of the return lines causing bubbles. I turned the pool off this evening to see if I could hear anything and it sounds like a whistle very close to the sand filter. I need some help as to where the air is getting in and what I need to do to fix this.
Pics! :goodjob: Remember, air can get sucked in while the system is running which is anywhere from the pump backwards to the pool skimmer. That's a suction side leak. But air can also get pulled IN past the pump (pressure side) towards the filter when the system is off. Sometimes you see a water leak pushing out (pressure), but not always. So when you hear air and water sloshing around when you turn the system off, air is seeping "IN" just about anywhere on that equipment pad.
Start slowly and methodically from the pipes that come up & out of the ground towards the pump, then inspect everything along the way until the lines go back to the pool. Make sure the pump lid and drain plugs have silicone lube. Be weary of those old ball valves. They can go bad and allow air in. Unions along the PVC line are great, but check them too since they have a small O-ring inside. The filter pressure gauge can also leak air in. Just take your time. It's a tedious hunting expedition, but you can get it. Process of elimination.
Thanks! I will try that and let you know what I find or what issues I may have.
Reactions: Texas Splash
Air is leaking out right here next to this screw. What does that mean?
You'll probably need to lift that MPV off the filter body to inspect the collar and bottom of the MPV assy. Should also be an O-ring around that collar that perhaps needs to be replaced or just some pool lube. If you do lift the MPV up, be very careful that the center standpipe doesn't try to lift upwards with it.
Reactions: Jcsmith9
Do you just remove the screws to lift it off?
Post a wider shot of the pipes into the MPV. You need to be able to remove the pipes from the MPV first.
However, yes, remove these bolts on either side of the valve clamp, and pull the mpv up slowly.
You can then inspect the matching faces on the MPV and tank, and the inspect the quality of the o-ring (#3)...which might need to be replaced. In either case, when you reassemble, use a silicone LUBRICANT on the o-ring.
