- May 24, 2025
- 7
- Plaster
- Liquid Chlorine
Hey folks,
New to TFP and to pool ownership; I purchased a house built in 1980 that had an existing pool (I believe resurfaced in 2023) and I've been systemically going component-by-component to get an understanding of the system.
I wanted to see if I could get some experienced eyes on the bubbles I'm seeing in the pump strainer - I don't have enough experience to know if this is a potential for concern or not. I recently replaced the strainer lid and o-ring, (thinking they might have contributed previously), but it's about the same now as it was before.
Here's some more information about my setup:
It looks like the pump must have been partially replaced in the recent past:
I don't think the amount of bubbles is getting any worse - it's been at this level for several months.
Anyway, I thought some of your deeply experienced eyes here might help me get a sense of whether I should dig harder into this, or leave it be and keep observing it.
Thanks for any advice!
Evan
- 9,700 gallon in-ground outdoor pool in Southern California - segmented into a spa (about 700 gallons) and pool (9,000 gallons)
- Plaster surface
- Using liquid chlorine
- The pump appears to be working fine: It primes just fine and holds prime consistently
- Pump is pulling nearly 100% from the skimmer, and it has one of those plastic things to create a vortex
- Pool level is ample, halfway up the skimmer opening
- The lid of the pump strainer is hand-tight
- Filter is DE, cleaned (not by me) about 2 months ago; nominal pressure is 15 psi
- No obvious issues that I'm aware of
- The motor (?) appears to be a Century Pool Pump Motor, 1.65 HP - I believe this one: https://www.regalrexnord.com/produc...-208-230-115-v-3600-rpm-56y-frame-dp-bpa450v1
- And the pump strainer appears to be a Pentair WhisperFlo 011513 which I believe is https://lesl.a.bigcontent.io/v1/static/whisperflo-datasheet
Evan
