Cool, looks like a redesign. Let us know if it gets stuck. I'd rather not have my modified year tires.Update: New Seagull Pro arrived today. I am currently charging unit. Two changes right off the bat are
1) Charger is about 1/3 the size of the original.
2) on the botton of unit there is a small wheel.
Wonder if the wheel is to help is not get stuck on the main drain?
Did it dump a good bit of the fine debris back into the pool as you lift it out? This is the robot I have in mine has been doing it since the day I bought itOkay, after charging it to full power it ran its first go and I was very happy with its performance. I should have taken some pictures of my pool prior but it had not been vacuumed except for my pulling somes leaves in a few weeks. I live in the desert ( Las Vegas Area) so I mainly get leaves, palm fronds and lots of sand from wind storms, plus my dogs( 2 Golden Retrievers) hair, lol. It picked up everything that was on the bottom of the pool and it did a great job I would give it a grade of an A. I set it to only work the floors. I am going to run it again today and add the walls or put it in auto mode.
It did use the entire battery on the one session so it will need to be recharged after each cleaning.
More pictures of what was collected
Mine has never dropped anything pulling it out. The basket door is always shut. I guess if a twig got stick in it, I could see stuff falling out. Make sure you push the basket down when putting it in.Did it dump a good bit of the fine debris back into the pool as you lift it out? This is the robot I have in mine has been doing it since the day I bought it
I’m hoping maybe it’s something easy I can fix otherwise I’ve got to get rid of it
Mine doesnt have a basket really. Just a screen over the bottom. And I cannot see that the screen snaps in place or anything. Just kinda sits on top.Mine has never dropped anything pulling it out. The basket door is always shut. I guess if a twig got stick in it, I could see stuff falling out. Make sure you push the basket down when putting it in.
Seagull Pro?Mine doesnt have a basket really. Just a screen over the bottom. And I cannot see that the screen snaps in place or anything. Just kinda sits on top.
I will check again to see if something is loose![]()
Personally, I'd rather have a refurb. They've fixed it with latest parts and tested it. New ones, it's a roll of the dice. Mine had issues the first month and they did send a new one. Customer service has been very good IMO.I have learned Aiper customer service is like talking to a wall. I returned my Seagull Pro purchased in May 2023 (direct from company) back to them due to it no longer charging, and they received it on July 8th. Two weeks later now (a month total since starting the return process), I am being told that there are no refurbished units to ship to me as the warehouse is out of stock. They even asked if I had any suggestions. I said yes, please ship a new unit vice a refurbished one, here is their reply to that idea:
“Thank you for your response. We have received your message.You may have misunderstood. Your machine has been purchased for more than a year. We can only provide you with a refurbished machine during the warranty period, and cannot directly replace it with a new machine.
Best regards,
Yolo
Aiper Customer Support”
Huh? Where in the warranty does it state after a year into the two-year warranty, you are only eligible for a refurbished machine? I then tried the “escalate your case” link on their email form after talking in further circles with Yolo, but I only end up with yet another reply from Yolo.
My main complaint here is where in the warranty does it state after a year into their two-year warranty, the customer is only eligible for a refurbished machine?
Did anyone else here have an issue with Aiper customer service and their warranty? I’ve read the entire thread here and it seems no one has tried yet to return one outside of one year since purchase. Am I being unreasonable in asking for a new unit while still covered by their 2-year warranty?
Thanks tcat. I’ve enclosed my basket in a filter saver sock, it seems to catch most of the muck.Personally, I'd rather have a refurb. They've fixed it with latest parts and tested it. New ones, it's a roll of the dice. Mine had issues the first month and they did send a new one. Customer service has been very good IMO.
Side note, I wish they'd do something about a finer basket. I modified one with 60 micron mesh and it does a great job at silt, but does clog up within an hour and pretty much picks up nothing after that. Something around 100 micron would probably be much better. I run my 60 micron an hour then switch to their 180 micron, does a great job.
