So far so good.
My pool is less than an ideal use case as it is freeform with a grotto, sun shelf, additional wall shelf, steep slope between deep and shallow and curved floor to wall slope.
The first couple uses I did auto mode which like
@tcat seemed to do a thorough floor cleaning but died prior to completing the wall. I used it today in wall only mode and I am very pleased with the wall cleaning so I think I'll flip back and forth. I will do a wall clean one day then a floor clean a different day.
We get alot of fine dirt in the pool and this does a good job of collecting that. My youngest came over yesterday with his dogs so today's haul was WAY more dog hair than I would have anticipated especially given that I only used wall mode today.
It does get stuck on my floor drains occasionally but manages to get itself off. My floor drains are poolfittings pebble drain covers with the risers installed. I had installed the risers thinking that it would improve the floor debris suction but it really did not so I may remove the risers and I'm guessing that will prevent it from getting stuck there.
Battery life is about 2 1/2 hours which is in line with advertised. Charge time is under 2 hours but I've not watched it that close enough to get exact charge time.
Build quality I would describe as refined. I had the smorobot previously and comparatively this is better. Fit and finish is on par with what I would expect from tier 1 manufacturing and much better than i expect from chinesium. From the manual it appears that there will be spare parts available.
The scratches on the lid and selector are a result of my laziness lol. The aforementioned smorobot cleaner came with a hook that had to be attached to the pole with a bolt and nut. Instead of removing it and putting the one on that came with the seagull pro, I tried to use it.... and it doesn't quite fit. The hook for the seagull is longer and flatter where the smorobot hook is more , well hooked lol.
The seagull does not do the stairs, does not appear to get on the sunshelf and does not get on the seat in the grotto.
I paid ~780 for it shipped which included the handheld vac and so far i think that a fair value.
Longevity is "to be determined" but between the 2 yr warranty and the 2 yr extension afforded by my cc, i can live with ~200/yr
Hope that helps
