Aiper Seagull Pro Review - 18 months in
rosensama
0
47
Austin, TX
Hi All,
I got an Aiper Segull Pro in late 2023 after reading some reviews here. The gist was "works fine, but who knows on durability". I decided to get one because I was tired of spending every year on expensive Polaris pressure side cleaner (280) parts. I had an old one that lasted for years, but the replacement parts were only lasting a few years. I figured if I'm going to spend so much over 2-3 years rebuilding it, why not see if the cordless robot can last that long.
Anyways, I've had it for 18 months or so now. I'm in Austin, Texas, so pool is open year round. Salt water generator. We get leaves in the pool, but nothing crazy. We have a egg shaped pool with a bench, a ladder and round stairs. Maybe 800 sq ft, 15k gallons.
I don't think it was worth it overall. At my price point, the Polaris works better. At higher points, maybe I'd try a corded robot.
Cons:
I'm on my 4th unit with a bit over 6 months to go under warranty. I've never paid for shipping either way and they've been generally helpful, but I can't imagine it lasting much longer than the warranty. I haven't just had one problem. It has failed to charge . . . I think it was the charger, but they had me ship the whole thing back. The knob has gotten stuck . . . they said it was salt water (which it is rated for). I had to replace the knob myself after they sent me a free replacement. Nothing hard, but maybe 20 screws so took a while. It has stopped running parallel, missing swaths of the pool floor.
The pool chemistry it's rated for is a bit off except for salt.
Your Aiper pool cleaner is best used in the water conditions detailed below
pH Value: 7.0-7.4
Chlorine: Maximum 4 ppm
NaCl: Maximum 5000 ppm
It's not as good as the Polaris at picking up stuff. If there's a lot in the pool it takes multiple runs. If there's a little, it might take multiple runs, depending if misses stuff.
It sometimes gets caught on the ladder. I doesn't clean the stair or the bench, but neither did the Polaris.
Pros:
It recharges pretty quickly and runs for a long time.
Support was prompt and never charged me. No hassle getting replacements.
It's way better for walls than the Polaris. I don't have to brush algae when I lose control of my chlorine level.
I prefer putting this in and taking it out to either putting the Polaris in/out or always having it rambling the pool and catching people with the hose . . . tempting the kids to do something bad.
It cost about the same as a new Polaris without a pump motor.
This is wild.
Its kept me on the fence since my 2nd pool was built. While I applaud the companies who stand behind their warranties, I have a short season and if i go a couple weeks without the machine, twice, what's the point ? The bulk of my warranty period will be off season or cold water that i don't want to use the robot because the gaskets shrinking will cause even more headaches.
Great thorough review!
I see the cheaper aipers on sale at the big “W” sometimes and I am tempted but then I remember how well my “budget” Intex pressure side cleaner just plain works & is waiting in the wings incase my dolphin fails. If I wouldn’t have gotten a great 2nd hand deal on my “new to me” replacement dolphin the intex would still be getting the job done. I run my cleaner daily for 7 months of the year. Sometimes twice per day. My first dolphin lasted approximately 700 runs/ 3.25 seasons. It was a refurbished unit. Obviously I wish it had lasted longer but for what I paid & the service value it provided I am not super upset about its life span. Time will tell how long its cousin will last but probably longer than my pool lol 😂
I’m debating buying one of these right now.
With all the discounts/coupons it would run about $479-519 in between the S1 ($479) and Seagull Pro Cordless ($519)
Is it a total waste of money? My pool is very small (12X8- pic attached) I just built it but looking for something to clear out small crushed pebbles from garden and various debris from the garden.
Realizing real fast that the white plaster I had installed shows every worm/bug/leaf
I sent the S1 back for another Seagull Pro. The S1 was a lot lighter, maybe different battery technology. But it worked terribly on my pool. I think it's a combination of the switch from wheels to tracks and the change in weight. The Segull wouldn't try to climb stairs or benches, but the S1 would. When it tried, it would get stuck and or disoriented. There would be large sections of pool it never cleaned because of this.
These models are rated for 1600 sq ft of pool, so your 96 sq ft should give them plenty of opportunity to get many passes over each section . . . as long as its not an area it won't go at all.
The S1 has a feature where you leave it in the pool all week and it runs for a short period every day, supposedly on one charge. I gave up on it before I tried this feature.
Note that old Seagull Pros are subject to a recall for being a fire hazard. Aiper told me that serial numbers starting with 61 were subject to recall and 62 are fixed.
