Hello,
I know you all are probably getting sick of me, so THANK YOU to everyone who is taking the time to answer my endless questions!
I purchased ahh-some before my spa even arrived haha. I've already disclosed in a previous post, I got too excited to get in my new spa and I didn't purge.
I immediately regretted it. It's been 2 weeks and the water is starting to foam and looking cloudy. I'm ready to purge, just as soon as the temp gets above freezing. We've currently been hovering in the 20's. I have a few questions though.
1. I've heard to scoop out the foam as it appears with a pool net and wipe the edges with a paper towel, do I need to try to always be getting ALL the foam out, or do I let it foam up and just wipe the gunk off the sides?
2. Do I need to blow out the plumbing in between purges? Unless no gunk comes out (highly unlikely), I am planning on doing at least 2 purges.
3. Do I NEED to drain in between purges, or can I continue to add more ahh-some until no more gunk is coming out? I saw another poster did not drain in between purges, but I wanted to make sure it was effective to go this route? Not draining would be ideal considering the outdoor temps we've been having...
4. Do I NEED to reheat the water before purging each time? This would add a FULL day in between each purge, again due to the outside temp being below freezing...
5. IF I am refilling, do I need to adjust alkalinity and pH? This took me a ~6 hours to get my alkalinity down to 50... Or, can I just add bleach?
6. Lets talk about "rinsing". Do you close the drain, fill up the spa and turn on the pumps to rinse them out, or do you just rinse the sides with a hose and let the water drain out?
7. I was told, it vitally important to dose with shock level chlorine during the purge, do you test and keep adding chlorine during the purging process (~every hour) or do I just get it up to shock levels and leave it? I plan on running it for 30 minutes, letting it sit for 2-3 hours, then running again for another 30 minutes before draining (or if a drain isn't necessary, depending on answer's to question #3), adding more ahh-some).
8. I purchased the ahh-some on amazon. I was so excited to try it, I used some in my jetted bathtub. I got zero results. No foaming, no gunk, nothing. The water looked great. Is it possible I got a bad batch or is my tub just that clean? We run bleach or vinegar through it once a month and rarely use it, but I was expecting to at least see the "normal" foaming. We tried adding more and more with no results. Thoughts? (for reference, I have the Ahh-Some "Hot Tub/Jetted Bath Plumbing & Jet Cleaner")
Again, I apologize for all the questions! I know I am probably over complicating things, but I really do appreciate everyone who takes the time to help!
Thank you!!!
Lacey
Thank you!!!
Lacey
