Trenching 2" pvc tomorrow and when I come up to the pool should connect with hard pipe or flex? I was thinking any pool movement may cause problems with rigid pipe? Also what connectors should I use or replace?
Hard pipe will be fine, I’ve got mine done that way. Make sure to put a valve in for each so you can shut down water flow if needed, and unions as well to make it easy to disconnect.
