Hi all, I purchased my home a year ago with the pool already installed. I assumed it was an in-ground pool because it is... well... in the ground. Going through some papers the previous owner left I found out it is actually an AGP built in ground. It is completely sunk in the ground and surrounded by a poured concrete pool deck like an in-ground pool would be. I think it is a Wilbar International Sharkline pool, but I am not sure. It was installed 8 years ago by what appears to be a reputable company (the previous owner left behind all the permits and inspection reports from when it was built).
I guess what I want to know is- does it being an AGP change anything? Is the maintenance different? Does it have a shorter life expectancy than an in-ground pool? I read that an AGP that is completely sunken runs the risk of the walls caving in if it is ever fully emptied, such as to change the liner. Is this true? We were hoping to change the liner in the next few years (we would hire someone, not do it ourselves if that makes a difference- we are not as good DIYers as some of you!).
Also, we have a Waterway Hi Flo pump, meant for AGP, but it is located at higher ground than the pool. That’s a no no, right? We are having some issues with the pump priming and someone suggested that could be the issue.
Sorry for the wall of text- I was thrown for a loop by my surprise AGP discovery and appreciate any insight you might have!
