I have a problem with our liner. I plan on replacing it with a new liner in the spring. It's been leaking for a few years. The weathered cover is going down with the water level. I'm concerned with the sagging cover might start pulling the pool sides in and collapsing the pool.
I'm tired of wasting money filling the pool. Public water and sewer taxes are pricey here in Jackson, NJ. Every inch of water in the pool is about 700 gallons.
(When the water level is very high, like max or overflowing at the skimmer, the water level stays high longer than when the level drops 4 to 6 inches or so. I guess there is a piece of liner somewhere that is being pushed tight and keeping the water from leaking faster than when the level drops. It's kind of puzzling to me). The liner is original, I'm not sure of the age, I'm guessing 17 years old. There are quite a few folds in the liner at the bottom and some on the sides. Repairs are next to impossible to last.
Well anyway, I am looking for advice on what steps I should take for the time period of winter to spring.
Should I leave the pool cover on? Pine needles are an issue being there are several Eastern white pines next to the pool. They are constantly entering the pool and on top of the cover. I noticed that there are a few bushels of pine needles on the pool cover right now. I'll have to scoop them out.
I just cut a few slits in the cover near the edge of the water line on the cover to alleviate the rain and snow that will further come into the pool. This is to slow the additional weight from pulling the cover and sides.
The weather for the next few days is above freezing and the water not icy. Next weekend the temperature is predicted to drop close to freezing here in New Jersey.
I'm thinking that I should remove as much water and pine needles from the cover.
Then remove the cover.
Either pump or siphon the remaining water from the pool itself onto the street or sewer, etc.
After emptying the pool, leave it for spring and pull the liner out at that time, making any needed repairs, changes, etc., just before replacing it.
I am open for all of your suggestions on what to do. Thank you!
