So- my nephew decided to help out and put a second just of bleach in the pool"just to make sure" ??
Chlorine level was sky high.
Now it is back down to 5-
However I ran through all the tests and here's where I am- I never know what to do first...
(I have not yet turned on the salt generator, as the temp is still under 50) below is a copy of my test results..
Chemical adding said:
9lbs stabilizer
1lb 10oz soda to raise pH
13lb soda to raise TA
25lbs calcium chloride to adjust hardness
(Qty11 )40# bags of salt
Which one do I start with???
Backyard
Build Type: Vinyl
Volume: 22000 gallons
Latest Test Result Summary:
FC: 5.5 (12 minutes ago)
CC: 0.5 (12 minutes ago)
pH: 7.0 (12 minutes ago)
TA: 30 (12 minutes ago)
CH: 25 (12 minutes ago)
CYA: 20 (12 minutes ago)
SALT: 1200 (12 minutes ago)
9lbs stabilizer
Backyard
Build Type: Vinyl
