- May 21, 2020
- 32
- Vinyl
- CircuPool RJ-45
Hi gang,
Our pump has a suction side air leak - based on the previous owner’s putty fix, and confirmed by a garden hose focused on the fitting, it appears to be the union on the suction side just upon entering the pump. If I had to guess it’s a loose connection between the threaded male connection to the pump housing. As you can see, replacing the union all together is tricky since there is less than 1” available near the valve assembly. Is it possible to just replace the male threaded portion of this union and expect a tight fit? Much appreciated! The air leak is minimal, and it never comes close to losing prime, I just want to do it right
