Hi All,
I'm new to the forum and I come seeking advice.
I have a roughly 20 x 40 ft pool. From what I understand, it is a gunite pool that is somewhere between 23,000 and 25,000 gallons and about 25 years old. It came with the house and I have been slowly learning about it over the past few years. From the outset, I knew that I would have to put some money into renovations as the paver coping is chipped and cracked. I believe the plaster is about 14 or 15 years old. The autcover mechanism looks quite aged and the cover fabric is about 6 years old. Every season at startup a half dozen or so tiles need to be reset. I have been told by my pool guy that they are starting to delaminate in places.
All of this to say that I was planning on a full renovation (plaster, tile, coping and autocover) next spring.
Unfortunately, my autocover has now failed in the form of a broken rope and the local company will not repair it as the fabric has a few cracks in it and they no longer deem it a safety cover. Thankfully, it is stuck in the open position.
This has jumpstarted my journey.
My current plan is to replace the paver coping with 8ft x 2 in thick x 12 (or 14) inch deep bluestone. I will drain the pool down a few feet and have the autocover guys install new undermount rails and finish the new autocover job.
Next spring, I will have the pool fully drained and then replastered and tiled.
Does this sound insane to anyone here? My stone mason is excellent and is willing to put up temporary tarps and meticulously vacuum during the coping removal and replacement process. I have worked with him before and he is a man of his word.
Will doing the coping before replacing the tile and plaster cause any issues? I don't want to invest in one part only to rip it out or cause larger problems later. Any thoughts or advice is welcome.
My alternative scenario is this: work with the autocover folks to buy a new system now, only install the fabric on the existing setup just to get things working, and then complete the renovation next spring with installation of the remaining new components (rails, motor, keypad, etc). I'd rather just buy a whole new system because my understanding is they are much more reasonable as a bundle than as individual components and I'd rather just do it all at once if I'm going to part it out over a few years for higher total cost.
That was long. Thanks for reading!
