Advice needed for installing Stenner pump injector
@Dirk , I'm thinking about this method for the above stenner pump setup which I questioned.
https://www.crmagnetics.com/Assets/ProductPDFs/CR4395 Series.pdf
If the pool pump is a single speed motor then a current sensing relay can be used. If the pump is a variable speed motor with a variable frequency drive, then the input current may not be the best measure of when the pump is running or not. At the very least, you’d want to have an additional flow switch in the plumbing to use as a safety feature.
What is your plan for using the relay ?
I don't have a plan was just thinking what may work but have never used one. Thanks for the insight !
It will work on a VSP. The CSR has a variable trip point...I run my VSP low and adjusted it for the lowest speed I run. I agree on the flow switch.
  • Love
Reactions: JoyfulNoise
If you don't have automation that tells you when your pump is [supposed] to be getting power, then I think a current sensing solution is a good idea, although I don't have any direct experience with this MO. But I think the problem remains: the pump could be getting power (somehow) but still not be pushing water. Maybe an impeller problem? Or plumbing blockage?
No, I think flow detection is the better protection. Because that's what actually matters: flow: good, no flow: bad.
And of course both is best: confirmation that your pump is on (or supposed to be) and flow detection. I have both. And wrote about it here, which I think you've seen:
Along with the flow switch installation, that thread includes a schematic for wiring the flow switch. It's kinda mixed in with other things my custom circuit is doing, so if you need me to separate out just the flow switch part, let me know.
