For the past 3 days I have been trying to balance the pH and TA on my new hot tub. I just performed my 23rd test. My untreated water had a pH of 7.8 and a TA of 120-130. I have had, during these 3 days, since I started treating the water, TAs ranging from 0 to 100, and pHs ranging from yellow to over 8.0. The only chemicals I have added have been pH down and alkalinity increaser, each added separately, each time using filtration plus 30 minutes of running the jets. I have gotten the TA to 60 twice, but with a pH of 7.8-8.0. Needless to say, I'm exhausted. I am going away in 3 days for an 8-day trip, and at this rate, I may not even have it balanced by then, let alone get to try out the tub. I did add a few inches of fresh water today, simply to make up for all that I have taken out by repeated testing, but that didn't seem to change the chemistry much. I am wondering if I need to add muriatic acid or borates. I intend to use the hot tub as a pool, at temperatures like those of a heated pool, and plan to allow my small dog in the tub. He doesn't seem to drink pool water, but, of course, a small amount could still be ingested. (As far as borates affecting a dog's fertility, he is neutered.) In previous months, I had 2 small AG pools that I kept somewhat balanced, without too much difficulty, but I allowed more leeway in pH (often 7.8-8.0), and had TAs of 100-130.
TA= 80
pH= >8.0
The hot tub guide recommends a pH of 7.2-7.8 and TA of 60-120. I have been trying to get a pH of no more than 7.6 and a TA of 60, based on replies on this forum to my previous posts and on what I have been reading online. My second last test showed a pH of 7.8 and TA of 80, which would be in line with the guidelines of the manual. I am wondering whether that is the best I can get.
