Hi I’m new to the forum living in the south of Spain and am planning a four day trip which leaves me with a bit of a dilemma as I add 14% liquid chlorine to my pool on a daily basis as required due to heat prior to changing to a salt chlorinator. I have a 65000 litre mosaic tiled pool with a cya level of 65 ppm at present and do not really want to put pucks in whilst away as we’ve not had rain for so long and don’t want to raise cya any higher if I can help it. I wanted to ask if adding say a weeks worth of liquid chlorine (7-10 litres) would do the trick rather than asking a neighbour to add it each day and if this would cause any potential problems? I keep my FC level at 6/7 ppm at present to compensate for cya level as not in use for winter.
Any advice appreciated
