My 16 x 32 in-ground pool is closed for the winter with all ports plugged and a sieve type safety cover on it. I want to add some liquid chlorine now while the water is still clear before opening in order to prevent algae and other problems between now and opening.
The Loop-Loc company recommended that I open the corners of the cover and add a gallon of liquid chlorine to each corner of the pool. The problem is that I worry about damaging the vinyl liner by adding the chlorine with no way to circulate the water.
Does anyone have any suggestions on a safe way to do this? I have an aquabot with a dead drive motor and am thinking of adding a couple of chlorine tablets or some granular shock to the filter bag and throwing it in the pool with the pump running.
Mike.
Mike.
