- Jul 29, 2017
- 262
- Plaster
- Pentair Intellichlor IC-40
The IntelliChlor manual gives this warning:
Do not add any pool water balancing chemicals (including salt) unless the IntelliChlor SCG is switched off.
A strict interpretation of that would be that you could not using automatic dosing systems if you have SWG. Since I don't think that is what Pentair means I am assuming they don't want non-diluted chemicals going through the cell. Obviously pouring muriatic acid directly into a skimmer would be a no no for many reasons. Do you really need to turn off the cell or is it acceptable to take reasonable precautions to ensure any balancing chemicals are well diluted before they get into the lines?
