We have an existing 15' x 50' ~29,000 gallon pool. It's about 30 years old now, with the plaster showing some age. The decking around the pool is looking it's age, and the location of the current equipment pad is... sub optimal. So as projects do, what started as a simple 'hrm, maybe we should get a spa' has turned into a big project. We're in the planning stages right now. We've found a local contractor, and aiming to start work in October 2021.
Here's an overhead shot of the pool. I marked what we're planning on doing physically.
I'm thinking we'll also add a SWG. Replace our aging and frustrating DE system with a cartridge (local regulations are DE are super restrictive).
We need to add some heater. I've been debating between a regular gas heater, and the Pentair hybrid ETi. We are planning on installing a fairly large solar electric system, and frankly would just rather burn less gas. BUT, I haven't read enough about the hybrid to know if it's a mistake or not. Anyone actually have one and have opinions?
Any key things we should be looking at or considering at this stage? If you've done a replaster + repipe, etc project, anything you wish you knew, asked, or thought about beforehand?
