This is my first full summer with a pool (bought the house last year). I did a lot of reading decided I'd follow the TFP method this year and have only used liquid chlorine. We have a well and fill the pool with it. The water is hard, and has contains Ferrous Iron, so this year I've been adding softened water to limit the iron and calcium, and have been using Muriatic Acid and aeration to lower the Total Alkalinity (180-200ppm all summer). I thought I've been having algae problem, but I'm starting to second guess my diagnosis.
I completed a SLAM over two weeks ago. I waited for two consecutive days of 0 ppm CC, <.5 ppm overnight chlorine loss, and the water was crystal clear. I could see the detail of the liner in the deep end from 30 ft away. The PH and TA were high (7.8-8.0). I been adding Chlorine when it gets down to around 4-5ppm so the level bounces between 4 and 8. The water remained crystal clear.
Three days ago I decided it was time to lower the PH and added a gallon of MA. The pool turned vivid turquoise, and slightly cloudy, with a yellow dust on the bottom (pics attached). This is the pattern I've been fighting all summer. If I SLAM again it will go away in another two weeks, but will be my 4th SLAM of the summer, and the stores around here aren't restocking chlorine. It seems like the classic signs of algae, but I have been extremely cautious this time to not let my FC drop below 3ppm.
I thought this might be the Iron coming out of solution, but the Pool School article seems to say that it is High PH that causes that. What am I missing?
Full FT-100 Results
FC 7
CC 0
PH 7.4
TA 180
CH 375
CYA 35
Full FT-100 Results
FC 7
CC 0
PH 7.4
TA 180
CH 375
CYA 35
