Acid tank connector
booboo
0
May 22, 2008
81
Marana AZ
The cable coming from my acid tank to my Intellichem is missing the connector at the end. See photo circled in red. The cable has bare wires that I rigged up and got connected. I would like to find the correct connector to make this right. Anyone know where I can find one of these connectors? I looked for a used pump on eBay with no luck. I don't want to pay $250 for a new pump.
Sorry you haven't received a response...maybe a bump will help...
Road Trip Dog GIF by Tomas Brunsdon
It looks like one of the dozens of variants of what is referred to as a "pin header". Could you possibly post a closer picture? Preferably at an angle were we can see the pins?
If you have a decent set of calipers measure the size of the pins (and note whether they are square or round) and the spacing. The most common are 0.025" square pins on 0.1" centers, but there are a number of other common sizes as well. Once you know that go to one of the bigger electronics distributors (eg Digikey) and use their part search tools to find something that matches.
I can see that board has already been worked on -- There was once likely a connector in the lower spot labeled "J10" where there are now wires soldered place. So one option you can consider is to simply replace both sides, the connectors on the board and the connector on the cable with something that will mate the hole spacing on the PCB.
