Hello everyone.
I’ve got an above ground vinyl lined pool. Chlorine, 2 years old with a sand filter and VSP.
I’m usually meticulous about balancing the water and following TFP protocols but I’m not sure how to handle this problem.
I accidentally let the skimmer basket get pretty full about 10 days ago and the water got a little cloudy. I figured I would clear the basket, backwash and then shock it overnight to clear things up.
The next morning, this stuff was at the bottom of the pool. It has been there each morning for the past week.
Nobody has been in the pool because of it so I don’t think it’s dirt.
The water has cleared up nicely. It’s clear and moving 24/7, but the substance persists.
Each day I vacuum to waste, backwash and rinse, and I’ve been trying to keep FC around 16ppm (CYA is 40).
pH, TA and CH are good per my Taylor kit.
I do have alot of trees nearby that regularly drop leaves into the pool. I don’t know much about phosphates and haven’t had them tested.
Not sure what this is or how to get rid of it.
