When i opened the pool a few weeks ago i had found that my gauge was cracked from the winter. In the past when i'd checked pressure with the old gauge, ie: last year, it was always something like 18 psi (i think), this with the solar going, the robot and return and side skimmer (models in my sig for most of this).
Since changing to a slightly different model gauge, it seems to be showing around 9 psi, though i swear when i first installed the gauge it was at or around 13, maybe not.
To test if the gauge is working i thought i did this right.. i shut off the side eyeball return and left only the robot running and there was no change. I also tried turning on my usually off second side port, no change. Even when solar wasnt active the pressure value was the same.
Of course I should verify that it read 0 psi when off (i think it did but need to double check).
I read that low pressure can be a problem before the motor or motor basket (i'd assume between the skimmer outlet and the motor as well?).
Unless of course 9psi is typical for this size system (pretty sure its not).
Anyone know off hand if this seems off in general?
Thanks in advance
Thanks in advance
