- May 11, 2021
- 973
- Vinyl
- CircuPool RJ-30
I read quite some interesting stories about how great a pool with borates feel, so decided to give a try. I’m going with Boric Acid for ease of use.
Pool is quite new, but seems I got a good handle on chemicals. My CYA is intentionally low due to necessity of using trichlor in near future.
My latest test results are:
FC: 4
CYA: 20
PH: 7.5
TA: 100
CH: 150
My TA is a bit higher than recommended, should I try to adjust it (acid + aeration) before or after adding borates? From what I read sounds adding acid after adding borates will make TA adjustments easier as it will cut the PH reduction from acid.
How long after adding Boric Acid for pool to be safe to swim (assuming PH is over 7.2)?
FC: 4
CYA: 20
PH: 7.5
TA: 100
CH: 150
