a few good lines for the times
Pv2
0
1,273
south east Arizona
Half of us are going to come out of this quarantine as amazing cooks. The other half will come out with a drinking problem.
I used to spin that toilet paper like I was on Wheel of Fortune. Now I turn it like I'm cracking a safe.
I need to practice social-distancing from the refrigerator.
Still haven't decided where to go for Easter ----- The Living Room or The Bedroom
PSA: every few days try your jeans on just to make sure they fit. Pajamas will have you believe all is well in the kingdom.
Home schooling is going well. 2 students suspended for fighting and 1 teacher fired for drinking on the job.
I don't think anyone expected that when we changed the clocks we'd go from Standard Time to the Twilight Zone
This morning I saw a neighbor talking to her cat. It was obvious she thought her cat understood her. I came into my house, told my dog..... we laughed a lot.
So, after this quarantine.....will the producers of My 600 Pound Life just find me or do I find them?
Quarantine Day 5: Went to this restaurant called THE KITCHEN. You have to gather all the ingredients and make your own meal. I have no clue how this place is still in business.
My body has absorbed so much soap and disinfectant lately that when I pee it cleans the toilet.
Day 5 of Home schooling: One of these little monsters called in a bomb threat.
I'm so excited --- it's time to take out the garbage. What should I wear?
I hope the weather is good tomorrow for my trip to Puerto Backyarda. I'm getting tired of Los Living room.
Classified Ad: Single man with toilet paper seeks woman with hand sanitizer for good clean fun.
Day 6 of Homeschooling: My child just said "I hope I don't have the same teacher next year".... I'm offended.
Better 6 feet apart than 6 feet under
This has nothing to do with COVID-19, but as a gearhead is one of my favorites.
TOOLS EXPLAINED:
DRILL PRESS : A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers.
DROP SAW : A portable cutting tool used to make studs too short.
PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH : Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW : A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK : Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW : A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR : A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER : A tool used to make hoses too short.
HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE : Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
ADJUSTABLE WRENCH: aka "Another hammer", aka "the Swedish Nut Lathe", aka "Crescent Wrench". Commonly used as a one size fits all wrench, usually results in rounding off nut heads before the use of pliers. Will randomly adjust size between bolts, resulting in busted buckles, curse words, and multiple threats to any inanimate objects within the immediate vicinity.
Son of a TOOL : Any handy tool that you grab and throw across the garage while yelling "Son of a" at the top of your lungs. It is also, most often, the next tool that you will need.
Louisiana has a new parish called Bayou Self
People must not cough near you
They must cough far away
If they want to cough near you
Tell them to far cough.
You wanted a reality show host as President. Well now we’re on Survivor.
  • Haha
Reactions: mguzzy and Pv2
