My pool has two 6-way valves to run the in-floor cleaning heads. Each valve is independent and run by separate pumps. I recently replaced the guts for both units and everything is working fine at RMP's above 2000. On one of the valves, the impeller stops spinning around 1800 RPM, the other will function down to below 1000 RPM. I run a scheduled program where the pumps run higher overnight and throttle way back in day/evening ( 1200 rpm). But now I can't. I have replaced these sorts of things several times over the years, and seasonally when winterizing, so I am familiar with the process. Does anyone have any tips on adjustments to fine tune this stubborn valve?
