- Aug 11, 2024
- 6
- Plaster
- Saline Generating Systems Breeze 540
Hi everyone!
We have a low profile A&A in floor cleaning system. System worked for a couple years. Since then we have had to replace the gear kit twice. It’s jammed again less than three months after a full gear kit replacement and the pool tech said the gears were fine but the bottom shaft of the top impeller had “worn down”. This was causing the gears below to etch a circle in the plate of the top impeller.
The impeller was replaced and the system worked for three weeks. But now jammed again.
Pool tech seems out of ideas. I am not sure where to go from here. Any thoughts are appreciated.
Pressure at the cartridge filter is 22PSI which is about the same as it had been when the system was working reliably for years.
Thank you.
Brian
Thank you.
Brian
