Thread: Polaris 380 housing loose
    N.E. South Carolina
    68
    The blue housing of my Polaris 380 is slightly loose in the front, and it won't clean the pool. I've looked at it (sort of, it's cold out there), and I can't figure out why the housing won't stay seated in the front of the unit. I'm assuming that this is the reason it won't pick up leaves.
    I have no real experience with the Polaris, other than cleaning out the bag. Anyone have any ideas what could cause the housing to be loose? Am I right thinking that this is the reason it won't clean? How does everyone get their Polaris repaired, send back to the manufacturer?
    Judy
    Designated "pool girl" for 18' x 40' in-ground vinyl pool built in 2006
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Polaris 380 housing loose
    Does the blue part have a seam all the way down the middle so that it comes apart in two halves, or is it one big molded piece with a smaller piece in the back near the top? A picture of what you're talking about would be a big help.
    Depends on how badly out of whack it is as to whether or not it would hurt the cleaner. You could take the blue housing off completely and it would still do it's job, but the housing could be rubbing against a wheel or something.
    When you say it won't clean the pool, what is it not doing? Picking up debris, navigating properly, staying on the floor?
    N.E. South Carolina
    68
    Quote Originally Posted by spishex
    It is one big molded piece.
    When the housing is not seated properly in the front, water shoots out of the housing, so it doesn't pick up debris.
    I'll see if I can get a picture of it.
    Judy
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    You shouldn't be seeing water shooting out of the housing. You'll need to open 'er up and look for a loose hose.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Yep, it is not the loose housing that is the problem. The water should "shoot up" the throat towards the bag, and shoot out the "butt jet" and the sweep hose. That's the only three places you should see water "shooting". Look inside, as suggested above.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
