I had a awesome Father's Day. We just replaced our old 24' ABG pool with a new Sharkline Matrix 24' x 54" from Pool Supply World thanks Fernando for the great customer service. I am going to use the old Pump & Filter over as it is already plumbed using PVC and includes my solar controls.
I would like to convert to Saltwater starting with a budget Krystal Klear Sysytem and adapt it into my current PVC plumbing. I am attaching pictures of the current plumbing layout inside my little pump house. I do have room for the SWG inside the pump house but not quite sure how to make the connections.
I plan on running the SWG at night using it's built in timer and a timer on my pump low speed.
Am I correct that I need to connect the SWG after the filter and then make a new exit through the wall to the Pool Return. I would put a 90 turn on the current return line connect to the SWG and then make a new exit line out to my return. By doing this the water running through the solar system will also be flowing through the SWG while it is not operating, is that a problem?
I will be installing the skimmer and return tonight after work (weather permitting again) and hope to start on redoing the PVC so any replies, suggestions, or advice from all is appreciated.
Dennis
Dennis
